Old 07-22-2012, 06:44 PM   #81 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
If you are too rich on the low end you can adjust the mixture with the pilot screws. They are usually covered with sheet metal covers but are easily removed.
I thought the honda 500 was water cooled. In which case 95% of the cooling is through the radiator and probably one cylinder doesn't run much hotter than the other.
I think you probably have some tuning to do. Perhaps using a O2 sensor or EGT if you need the tools.
I have a Virago 700 that is mechanically stock except for the carbs. I made my own single carb manifold and run a dirt bike carb on it. All the tuning jets are available from most any dealer or Sudco.
Noah Webster, 1787
