Old 07-22-2012, 08:49 PM   #82 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
As I have mentioned in privieus posts there are a series of solution options any of which may do the trick. I will try them all in order of dificulty of implementation. The most difficult is the relocation of the radiator and/or the addition of a second radiator positioned at the rear of the bike dumping the hot air into the wake. In the end I also want to run the same smaller main jet size in both carbs. how effective the relative cooling of each cylinder is could be contoled by restriction of flow 60/40 so that the rear cylinder gets more of the flow and or by the order of flow through the system...
The Yamaha 250 V-twin runs a single carb that feeds both cylinders so they seem able to avoid the problems that Honda solves with two differant main jet sizes. What Yamaha does I have no Idea so I may have to look into it.
