Thread: Singh Grooves
Old 07-22-2012, 11:48 PM   #21 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
documented improvement
" Why is this not in the unicorn corral? It's unproven and totally speculation. "
there is a documented improvement in fuel economy at a common load and rpm with that particular 10g engine , shown is a before and an after
same engine
before
and
after installing singh grooves
no other variable
upwards of 20% improvement at the same load - that is significant
it is not rational or accurate
to say that this improvement is un documented and pure speculation with this 10g engine -
read the test description - then read the test results
if your opinion at that time does not agree with posted facts
that is fine
run the test your self , post your test results , prove these posted test results to be
in accurate ... other wise these test results stand .
The Following User Says Thank You to mwebb For This Useful Post:
Pawtuckett (07-25-2012)
