Originally Posted by touring21
That worked, somehow I did not download the manual you have listed
I am very happy with the end result. I was wanting to get another push button switch as I tried to modify the one you supplied to fit into the small space I have and it got a little twisted? Can you help me?
Good to hear you got it working. Would nice to see pics about your installation, where you put it?
Does that twisted button works? If it is not broken, dont bother to change it - if needed, twist it back to its original shape.
If you still need to replace it, go and search ebay with keyword "tactile switch right angle".
Here is one offer - 2 buttons 0.99$
2 Pcs Momentary Right Angle Tactile Tact Push Button Switch 6 x 6mm x 10mm | eBay
