Around here most cars rust out before they reach 500,000 miles, but if rust is not an issue and you replace stuff as it wears out then it should last forever, right? but I see a lot of people who keep driving cars that are broken and who just ignore issues, I had my neighbor almost scrap her car because it needed new spark plugs! a car gets an issue and it gets traded in or sold.
If you can read, read your owners manual! it often tells you how often to check stuff over on your car, oil changes at 7,500 or 10,000 miles unless you are letting it idle a lot, increase tire pressure for highway driving, change your brake fluid so you don't get water rusting out the brake system, fix stuff that is causing excessive wear.
