Old 07-24-2012, 11:13 PM   #14 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Originally Posted by jimepting View Post
It isn't obvious to me that that is a test of rolling resistance or fuel economy. The dyno rollers are only about a foot in diameter, so the tire contact patch is completely different than street conditions.
It should still translate you could (assuming the dino allows load control) run the car to 80mph with a very small load at stock psi time it then do a 60psi run followed by an 80psi run keeping everything the same. Then you just take the percent change and you will have a repeatable measure that will hold the same for all surfaces under the same conditions as the only change is the psi.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
