Old 07-25-2012, 01:14 PM   #1 (permalink)
nailers
tire size vs efficiency question
Hi, I have a 2001 Volvo V70XC with AWD so I'm not getting great mpg no matter what I'm afraid. It's time for new tires so I was reading threads here about efficiency. I saw a lot from Tire Geek refering to Barry's Tech that wider profile and taller tires decrease rolling resistance but increase drag and there's some discussion about the speed at which drag is more critical. The OEM size is 215/65R16 98H which if I don't drop down to T rated leaves 2 choices. I've been told that the load factor 98 is important so I want to stay at that, which rules out a lot of "eco" tires. I'm also limited to what's in stock at a local vendor (long story) which is: Michelin Defender GreenX 215/65R16 98T 22lbs, Michelin Latitude Tour HP 215/65R16 98H, Pirelli Scorpion STR 215/65R16 98V 24lbs, Michelin Primacy MXV4 235/60R16 100H 28lb, Sumitomo Tour Plus LST 215/65R16 98T 24.5lbs. Any fuel efficiency advice? From what I read maybe the 235/60 is the way to go. I only get 20-28mpg anyhow, with those I'd have a really good tire. Thanks.
