Originally Posted by turbovr41991
I was pretty confused when I was looking at the thread topic of D15Z1/VX and seeing pictures of a turbo kit.... Lean burn and boost would be very problematic.
I was thinking the same thing at first. but then I read on... nice job on the rebuild.
This is a very cool project. given that the VX motor only produce 97hp and the sedan is heavier than the hb, have you considered lighten up the weight of the body? chassis acid dipping, or removing unnecessary parts..etc
under body belly pan and rear diffuser will also help reduce the drag of the longer body
keep up the good work
