Originally Posted by MetroMPG
WAG = Wild A## Guess!
Is it a 12 volt system? I thought those golf cart gauges were simple LED voltmeters.
WAG, Good stuff.
No, it is a 48 Volt System, I've got 4 12 Volt Flooded Lead Acid batteries in series.
I think the Golf cart ones are either LED/ analogue with Red (low volt) to green (high volt), key here is not assume that the operator knows what 44 volts means.
