Old 07-27-2012, 12:16 AM   #14 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Originally Posted by TOOSTUBBORN2FAIL View Post
Thanks, I've been meaning to get the top done, just havent done it yet. Need to get it done before my bday concert.
One tip for ya: When you go to cut the plastic sheeting, to get the curve of the hood/bumper, just put it slightly under the hood until the two corners line up and are under... leaving the curve to overhang in the middle of the sheet. Then, take a sharpie to it... it was very easy and fast. Cutting straight, however, is a pain.
Also, when I did my 4 angled peices, I just moved them back and forth to get the proper height. The two sides first, then did the middles. Took a little bit to get it perfect, but once I did, was easily to line it all up.
Is there any recommended glue for putting cloroplast together? I think hot glue would melt in hotter temps...
