Old 07-27-2012, 10:46 AM   #13 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
If you have an injector signal to tap into there is a way to measure fuel usage.
Older, non-common rail systems wouldn't have a signal to tap into. Newer, common rail systems do, however, there's a few issues with that. First, common rail systems typically inject more than one pulse of fuel per cycle (typically 2-5 pulses). Especially with small pulses, twice the ontime does not equal twice the fueling--it's highly non-linear. Secondly, common rail systems have large variations in injection pressures, depending on the speed and load your at (3,000 psi vs 30,000 psi), so you'd have to know both ontime and rail pressure to acurately determine fuel injected.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 4 Users Say Thank You to Diesel_Dave For This Useful Post:
Daox (07-27-2012), Ryland (07-27-2012), slowmover (07-28-2012), UFO (07-27-2012)
