Old 07-27-2012, 01:39 PM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by scivicblu83 View Post
I did see the mods here first then applied them to my car. but alot of my inspiration comes from me working on airplanes everyday.
The car + tail looks like a wing in side view
can you recommend what to paint it with? as far as road use it does great, it is really stiff.
From
Coroplast | Frequently Asked Questions
Q: Is it possible to paint on Coroplast?
A: Krylon FusionŽ Spray Paint for Plastics will provide a thin durable layer. Follow the manufactures directions for application of the spray paint. Brushes and rollers are not recommended for direct application of paints to Coroplast because the paint layer is too thick and can easily peel and delaminate. For art projects you may use brushed application of compatible paints on top of the "primer"/ base layer of the Krylon FusionŽ Spray Paint for Plastics.
The Following User Says Thank You to euromodder For This Useful Post:
sustainable sam (09-22-2012)
