Old 07-27-2012, 10:02 PM   #95 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
What I will try next is a 1986 larger radiator, a relocated fan with extra ducting and some form of heat sinks added to the system to increas surface area cooling. Replace the #38 with #35 slow speed jets and install #112 main jet in the rear cyclinder carb to match the #112 in the front cylinder carb. hopefully this is enough to get into the 80 - 90 mpg zone with consistancy.
I will also design and build a new front fender that improves the airflow around the front wheel and forks, and directs more air at the bottom of the radiator.
