So much for the 900 mah that is stamped in the left front corner.
![EEK!](/forum/images/smilies/eek.gif)
Wonder if they are purposely mislabeled for customs reasons?
Strangely after that gorup buy I remember seeing an article about a batch of defected cells that had a crease in them, like those.
Think I got a good dozen of IMA cells that are worth a dam and similar in capacity. I am going to try and make a 14 volt 6.5 amp hour battery out of them for under the hood. Then hook a 5 watt solar panel to that as well.
Then of course remove the 12 volt starter with the lead acid battery.
