Originally Posted by Daox
These batteries won't be going in the Prius, they'll be used as the starting battery in my Paseo. They'll be replacing the group 24 lead acid battery that weighs about 40 lbs with this which will weigh about 5 lbs.
sorry, I should have read more closely. I understood you were using it as a starting battery for an ICE.
My experience is EVERY modern normal running vehicle has 14.0 to 14.4 or so volts, fully charged, and engine running.
I have a small automotive shop, and we specialize in fuel injection and electrical issues, and battery voltage at idle is something we pretty much always check.
