Originally Posted by NoD~
Is there any recommended glue for putting cloroplast together? I think hot glue would melt in hotter temps...
I think you meant Coroplast...
Hot glue is okay fer filling in holes in Coroplast but when used on Coroplast...it will detach over time when under stress.
I've used 3M Super 77 spray adhesive with good results. Not sure how long it will last though. The spray adhesive (when applied properly) will handle most tasks...but if you use it on Coroplast in a high stress arena...I'm not sure it will be able to handle it.
