Old 07-29-2012, 03:09 PM   #2 (permalink)
some_other_dave
It should work, but you may have to fiddle with settings and such. That assumes that the Jeep has a vehicle speed signal and an injector signal that the MPGuino can read.
The build is easy for anyone with experience soldering. The components are normal sized, none of the tricky (and tiny!) surface-mount stuff, and it goes together nicely. It is only a circuit board with buttons and a display, so things like an enclosure to make it look nice are up to the user to figure out.
-soD
