The biggest challenge is that the Velcro I have holding my ScanGauge in place, slips when the car gets hot, which makes turning on the second monitor more difficult...
Where do you have yer SG mounted? Got any piccies of how you have it set up?
I have found out over time that heat and gravity will always pull the adhesive from the Velcro. I've used a nylon wall plate to support my SG before I went with my UG. I made a custom mount fer my UG, too.
