Old 07-30-2012, 11:21 AM   #800 (permalink)
njakts
ok! success!
my obduino works with Elm327 and v193
Code:
 // ask protocol
  elm_command(str, PSTR("ATDPN\r"));
  // str[0] should be 'A' for automatic
  // set header to talk directly to ECU#1
  if(str[1]=='1')  // PWM
    elm_command(str, PSTR("ATSHE410F1\r"));
  else if(str[1]=='2')  // VPW
    elm_command(str, PSTR("ATSHA810F1\r"));
  else if(str[1]=='3')  // ISO 9141
    elm_command(str, PSTR("ATSH6810F1\r"));
  else if(str[1]=='6')  // CAN 11 bits
    elm_command(str, PSTR("ATSH7E0\r"));
  else if(str[1]=='7')  // CAN 29 bits
    elm_command(str, PSTR("ATSHDA10F1\r"));
had to uncomment this part to get it working...
now having problems with startup after eingne is been off. I think I will solve it with adding a delay on-off relay on power line
