Old 07-30-2012, 05:08 PM   #19 (permalink)
LocoJason
HocusPocusSlocusGocus
Slocus - '00 Ford Focus ZX3
Originally Posted by euromodder View Post
The sort of issues I'm having with mine - frequent, continued regenerations taking 20 or more miles, up to a staggering 50 miles - apparently is also killing the ceramic matrix of the DPF
Shutting down during regeneration, also turns on the rad fan @ full blast for up to 10 minutes.
Opening the hood, the heat radiation is massive.
I have no idea what type of system your vehicle uses, however if regens are taking that long I would want to believe there is something wrong. Often times they use a delta pressure sensor to determine soot loading. If the pressure sensor has gone bad, it may be the cause of your frequent/extended regens.
There are two ways to become rich; earn more or want less.
