Originally Posted by slownugly
update: first tank of gas with the new oxygen sensor increased to 47.9 mpg with a very smooth transition into and out of leanburn. planned mods are mpguino, volt meter to monitor either the injector pulse width or oxgen sensor voltage in lean burn, and vaccum gauge all while maintaining a stock instrument cluster feel. also new struts and lowering springs with alignment. i will start a project thread when i start the mods
Which struts and springs are you looking at? I'm just about in the same place you are at the moment.
Didn't know if I shoulda just get cheap stuff at autozone, find some used integra gsr parts, or get some aftermarket coilovers or something
