Old 08-05-2012, 02:26 AM   #2 (permalink)
baldlobo
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
a multimeter would help out in figuring out what sensors to replace.
for instance you could have started your engine; then while idling get under the truck and see what the o2 sensor was doing, voltage should have read no higher then 5 volts; stoich ratio is 2.35volts and 0 volts would mean it's dead
