Old 08-06-2012, 12:00 PM   #1 (permalink)
reb01501
RebCivic - '12 Honda Civic EX
Coast in-neutral vs in-gear: I've been challenged to show the numbers
... which I thought would be easy to do by searching this forum. Well, it's turned out to be easier said than done. I've been through several threads where I expected to find the numbers to back up the logical conclusion that coasting in neutral loses less momentum and therefore results in lower fuel use. However, nobody seems to have done an A-B-A comparison, much to my surprise. The closest I've found is this post:
http://ecomodder.com/forum/showthrea...html#post41066
But he didn't do full tank comparisons of the techniques, which is what I think will be the best (only) way to convince the doubters. Has anyone done such a test and can post the results?
I know that the idea, once correctly explained, is so logical that testing it seems absurd, but some people take quite a bit of convincing.
