maybe the 50mpg bar is easy to hit for some of you, but 3 tanks of fuel after my purchase, I'm not there yet. I'm averaging 45mpg, all freeway driving, Livermore to Paso Robles and back at about 75 deg F and 65-70 mph.
Let's see... new air filter, cap, rotor, platinum plugs, O2 sensor... check. 40psi in the tires, check. Compression 210, 200, 210 within the magic 5%, check. I'm doing the front axle/cv joint and brakes tomorrow, then back to chasing mpg. Timing? TB pre heat hose?
