Old 08-09-2012, 12:56 AM   #134 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Automatic transmission
I got the transmission moved off my utility trailer, set up on blocks upside down so I can get to the bolts at the 'bottom' and took some pictures. This one tells you pretty much all you need to know .... YES, this is DEFINITELY FAR above my mechanical skill. I likely won't be getting this automatic transmission working, re-installing a bunch of hydraulic hoses, faking vacuum signals from the engine, etc.
I will concentrate on getting the oil back into the transmission, and getting the transmission back into the truck so that the transfer case will work properly.
I measured today and it looks like the transmission will JUST FIT under the front supports of the front end if I can get the truck up onto my car ramps. But that's a topic for the next post.
