1. With the ignition switch OFF, remove the distributor cap.
2.remove the two screws to disconnect the BLK/YEL and the WHT/BLU wires from terminals A (+) and B (-) respectively.
3.Using an ohmmeter, measure resistance between the terminals. Replace the coil if the resistance is not within specifications.
Primary Winding Resistance (between the A and B terminals): 0.6 - 0.8 Ohms.
Secondary Winding Resistance (between the A and coil wire terminals): 12.8 - 19.2 kOhms
NOTE: Resistance will vary with the coil temperature; specifications are at 20°C (68 °F) .
