Old 08-10-2012, 11:18 PM   #1 (permalink)
pete c
Altitude and hills = better mpg
Just got home from vacation in California. Borrowed a friend's Toyota motorhome for a trip to Tahoe and Yosemite.
These RVs with the 22RE 4 banger and auto generally get 15-17 mpg driven conservatively. The tank from Lee Vining to Mariposa involved crossing Tioga Pass, which is around 9500 ft, driving down into the valley and then up to Glacier Pt at about 7200 ft. I averaged 18.3 for this trip.
The owner, according to his logs had been typically getting 13-17 mpg. I was traveling with a heavier load, 4 people vs 2.
I suspect my better mileage came from being very patient on the climbs (1st gear for long stretches climbing the passes) and doing some minor hypermiling (coasting in neutral on long downhills that weren't too steep). Wouldn't dream of EOCing an auto, especially one with a house on its back. I believe holding first gear on the climbs was vital. The auto in this thing is a 4 speed with very wide ratios. On a steep climb it will pull first gear effortlessly at 25 mph with almost no throttle input, but, if you leave it in drive, it will shift to second and it pretty much falls flat on its face. It will however lug along with lots of throttle. I suspect that this much throttle at that low an rpm is not a happy place for it. So, I left her in first and let the little 22RE spin its heart out at about 23 mph or so. And made good use of turnouts for faster vehicles. The temp guage for this fantastic engine never budged from its normal position, just below 1/2. Not bad for a 4 banger dragging a house over a mountain.
The trip from Mariposa back to Watsonville, I came within a hair of cracking 20 mpg. I suspect this is due to the nice gradual loss of elevation from the Sierra foothills to the central valley. Much of this was spent at 50 mph barely into OD with almost no throttle. Wish I had a scanguage as I'll bet that damn thing was getting close to 30 mpg in this mode.
Is there any chance that this 1989 vintage engine uses DFCO? I suspect it doesn't. Next question is would installing a manual CO on an automatic tranny engine be wise? Would the auto keep the engine spinning during FCO or would it stall?
