Old 08-13-2012, 12:22 PM   #28 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Originally Posted by Ryland View Post
The truck project that I've seen had the gas engine driving the rear wheels and the electric motor driving the front wheels with the motor in the location that the transfer case would live, this was on a Ford Ranger and I thought that it was a pretty slick layout, the Ford Ranger is also common to have an extended cab where there is enough space for 12 6v golf cart batteries in the rear of the cab with enough space for solid racks and head room to check water, a sheet of clear polycarbanite and a small vent out the side or back window would take care of most safety issues.
But Ben, you have an S-10 so I'm not sure how everything lays out on that vehicle, but I do remember it as being a top choice for EV conversion because of the frame rail spacing under the bed.
Beat me to it.
I think it would be easiest and most efficient to have the electric motor drive the front wheels and the diesel drive the rear. That way, the Diesel and transmission can be in there proper configuration, and adding the electric motor where the transfer case would normally be would be a great solution.
That way, you have 3 options. EV Only, EV+Diesel (Assisted towing, acceleration, 4wd, etc), or Diesel Only... almost seemlessly.
I think you may run in to a lot of issues putting the E-motor inline between the transmission and the driveshaft.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
