Old 08-13-2012, 05:49 PM   #29 (permalink)
some_other_dave
Originally Posted by 02ws6 View Post
I thought I might run into an issue with using the D15Z1 flywheel and a CRX Si clutch. But honda did it again and turns out all the disc diameters are 210mm..
There are differences. At least some of the 88s had a different spline count on the input shaft of the transmission. So the clutch disk has to match that. I have heard rumors of some sort of diameter difference between the 88-89 and the 90-91 cars, but I haven't actually done research into it. I was only interested in my 1990 at the time.
-soD
