I got most of the wiring done except for the side markers lights and the extra brake light because those have to be done later when I get the window and some skin on.
It's a little sloppy, but it works and that's all that counts.
I ran into a little problem because on the Ford Focus, the tail lights bulb only has 3 wires which means the STOP/TURN function share the same wire. Since I decided to have independent turn signal lights, I can't use a signal with a STOP function because all brake lights have to be red not amber. I plan on tapping into the signal under the dashboard near the steering column.
