Old 08-13-2012, 09:22 PM   #20 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Installed the volt+ amp. meter today.
I added 1.5k ohm resistor to the power feed which drops input voltage from 50 ish down to 15 ish.
Meter appears to work very well for the price.
Lowest speed that the controller will do is about 2.5 amps, max continuous draw out of water is 10 amps, and peak acceleration draw out of water is about 60 amps which I assume will be approximate draw loaded in the water.
I also learned that the state of charge meter does work, you just have to shut the motor off and press the battery button (which is the momentary bit after off). Very nice to have.
Next time out I'll have some decent data.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
