Old 08-14-2012, 05:03 PM   #141 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
A vacuum gauge will give you a LOD equivalent. ~13 psi MAP is about the same as 85 LOD. You'll have to translate if your gauge uses other units.
That's a good target if you're not using lean burn. Others here can advise you on best practices with LB.
