Old 08-14-2012, 05:06 PM   #10 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by some_other_dave View Post
Do you know what coolant temperatures your car "likes"?
Coolant temperature stabilizes at 78°C and it's hard to get it over 82°C without blocking the upper grille. If I block it (winter) the temperature will go up to 88-90°C, but often falls back to ~80°C when hypermiling. I believe that the engine "likes" to be closer to 90°C, consumption may be a tad bit lower then.
Originally Posted by rvpps2rocks View Post
when does the grill open?
The upper grille is blocked November thru April. Both sides of the lower grille are closed when I start the car and I open the intercooler side when the coolant warms up to ~70°C. I open the radiator side only when the coolant temp stays above 90°C, to keep the fan from cycling on too often (turns on @ 97°C, off @ 89°C).
