Old 08-14-2012, 07:06 PM   #32 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Barely fast enough.
A drive shaft on 3.08 gears with 30 inch tires is only going to turn 2100RPM.
That motor looked like a 13'' and those rev out to at least 5000RPM.
I just dont know if they like turning at real low speeds.
An DC EV motor can easily handle low RPMs, you just loose
Efficiency and Cooling
Meaning as long as he doesn't over do the amps at low RPMs it will work just fine, in fact many times low voltage DC motors only spin about that fast.
Where he can run into trouble is when the RPMs start getting in the 1200rpm and lower if he is stomping on it for extended periods.
