Why don`t you just turn down the fueling a little and then you can floor it without worrying about smoking on WOT?
Just try it, if it doesn`t work you can go always go back to more fuel. On a diesel you can`t screw up the engine with wrong fueling like you can on a gasser.
Are you running it on biodiesel or pure dinosaur juice? The bioD tends to smoke less.
