Old 08-15-2012, 01:11 PM   #53 (permalink)
Prophecy99
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
Originally Posted by 93Cobra#2771 View Post
I have done a lengthy test of using Marine Spec TC-3 2 cycle oil. Mixed at 1 oz/5 gallon. There is a big thread on it here:
Been testing - LS1 Performance Information
My results on fuel economy are inconclusive due to the climate change as I got into my fourth and fifth tank. However, my escort idles noticably smoother. Fuel pump is a lot quieter. And it is definitely easier starting. It is basically billed as a top end lubricant and fuel system/top end cleaner.
I've been using it in my fourwheeler, and it is SO much easier to start now compared to what it was. Now it will start after about 3 or 4 turn overs, compared 7 or 9 before. It was getting to be a bear to start in cold weather.
I need to break down the data in fuel logs and see if I see any trends in there for sure. Just glancing at them again, it appears there may be a decent increase in mileage trend. I wasn't using it for mpg, but for top end cleaning/lubrication.
I am surprised this method of adding Marine Spec TC-3 2 cycle oil. Mixed at 1 oz/5 gallon hasn't been thoroughly disscused here? am I missing a thread. This additive seems too good to be true for states that only have gas diluted with ethanol.
The Following User Says Thank You to Prophecy99 For This Useful Post:
WesternStarSCR (12-04-2012)
