Originally Posted by stillsearching
The problem is I have no clue how you even add a hitch to a motorcycle, which ones can take them
For small motorcycle trailers, the hitch is usually mounted on the swingarm - I've seen them one-sided (with a small ball joint) and two-sided (with a EU standard ball-hitch).
Goldwings are used to tow cars in Japan and the UK - they can easily get through congestion to get to the stranded vehicle. That means they tow up to about 4 times their weight.
