Old 08-15-2012, 07:20 PM   #7 (permalink)
aerohead
length
Originally Posted by rvpps2rocks View Post
What i wasnt sure on was what do you do if the length does not equal the height of the radiator, Im assuming your referring to the image below
yes,this is the animal.And it does need the length and gentle wall divergence for no flow separation inside.
Your car already has good leading edge radii,so bumping out the nose to accommodate the duct length might not in itself lower drag (it might in crosswind),but if you did it,you'd have a worry-free monster grille block.
