Originally Posted by rmay635703
The injection pump if I tear apart part of the top end has a tiny hole that if aligned perfectly allows me to turn a screw that controls the IP pressure which refers to how much fuel it can give. It also has static timing which I should probably touch because of how I intend to use the truck.
Injection pump....should have figured that myself but was probably brain dead due to the hour.
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
