Old 08-15-2012, 09:09 PM   #12 (permalink)
thomason2wheels
wrx4me...
no worries - '91 Subaru legacy L
90 day: 31.45 mpg (US)
weevee - '08 suzuki vstrom dl650
90 day: 61.22 mpg (US)
wrx - '09 Subaru wrx sedan
90 day: 29.8 mpg (US)
Big Bright Green Pleasure Machine - '09 kawasaki ninja 250 se
Connie - '09 kawasaki concours
aha....
Originally Posted by RiderofBikes View Post
Sure towing with a bike can be done, but thats a totally personal option! those who do pull anything usually arent riding a 250! Mostly cruisers of some sort.
Lower seat height, lower frame height, weight distrobution is favored to the mid/front of the bike(the rider evens that out) when riding. Avaliable hitches are usually mounted on the lowest point of the frame or FIRMLY mounted body fairing as close to the rear of the tire, safely.
Anything that ofsets the load "triangle" will already compromise the bike, unless ballast weight is added to the front, even a passenger of substatial weight disrupts this balance, will surely present unsafe conditions from the get-go.
Like Europe using Goldwings to navigate through traffic, deploy a rolling car skid, and tow the vehicle away. While its practical and economical, the bikes weight is about equal to the front of the car it must support/pull behind it on the skid. The frame and suspension have been beefed up as well to distribute the load as even as poss
I suspect a 650 vstrom would do what u need with reasonable weight and power reserves. Relaatively inexpensive used, combfortable seating position and nearly 60 mpg easily achievable one up, possible 2 up as well. Any questions about the strom i am happy to answer.
If this is a "just gotta do it" type things, I'd go with a 2cyl for torque with relative hefty weight >400lbs, with a Linked-Braking System of some sort. Buell comes to mind, while still being "sporty". But, for longivity and greater Load bearing design, virtualy anything Shaft Driven would be more suitable
Sorry about the reply....tablet not friendly with forum..grr
