It this not exactly how Toyota puts an Atkinson cycle engine in the Prius? Its a Yaris engine with a different cam and the hybrid motor masks the poor low-end torque of the engine.
Holding the intake valve open beyond TDC vents off pressure, effectively reducing the compression ratio making it possible for high ratio engines to run low octane fuel.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
