Old 08-16-2012, 01:14 PM   #1 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Converting Gasoline Pressure washer to Electric
My first ever Ben Nelson Style Gasoline to Electric conversion.
I've got a Gasoline pressure washer with a shot 3500 rpm (rated) gasoline engine, and a 3450 RPM 2HP continuos duty 110 volt motor from an old air compressor that blew a head gasket and was upgraded (now 16.9 cfm @100 psi).
I figure that they should go together, I'm guessing that I may need to run higher flow nozzles, but that is a bridge that I'll cross when I get there.
Pump has a female 3/4" keyed shaft input, and the motor has a 5/8" flat shaft.
I just ordered a 5/8" set screw type coupler and a 6" piece of 3/4" keyed shaft.
I am planning on turning down the 3/4" shaft on one end (in my lathe) to fit inside the 5/8" coupler. Then assembling as follows Motor with 5/8" male shaft->Coupler with 5/8" on both ends->Custom 5/8" male in 3/4" male out shaft-> pump with 3/4"female input.
Also Planning on making "L" Shaped braket to hold motor at bottom and pump on face with over size holes for adjustment.
Any ideas/ comments are highly welcomed.
Few Pics
Pump Top with adjustable bypass (probably will need to be turned down)
Pump input, feels like it has 2 bearings, anybody think I should tear it down to find out?
Old Air compressor Motor.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
