Old 08-16-2012, 10:36 PM   #7 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by 02ws6 View Post
Just a tip on the next trans you may do..
When you use the clutch alignment tool, lift on it just a tad and then bolt down the pressure plate.. Then probe the clutch and flywheel with the alignment tool to make sure everything is smooth.. Just because you use the tool doesn't mean its lined perfectly.. Ive fought a few transmissions and doing this have yet to fight another one to get in the hole..
I didn't have a alignment tool, I was using a socket wrapped in electrical tape. That could've been part of the problem, but I know I didn't have the trans lined up very well with the engine at first. It went right in once I got it straight.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
