Get her an UltraGauge. Set it up for her. Instant, short trip and trip mpg are the most important things. Throw in instant mpg and you've got four big, easy to read numbers that don't require any interpretation.
I put coolant temp on hers, and ended up removing instant gph to fit ambient temp because she had the cluster set to show the outside temp instead of the odometer (???).
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
