Old 08-17-2012, 02:29 PM   #3 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
1) VTEC engages when rpm goes above 2500.
2) Once the engine reaches normal operating temperature, it runs in lean burn whenever the manifold pressure remains above a preset limit (under low load, mostly closed throttle). Lean burn limits are controlled by manifold pressure Usually you can feel a slight stumble as the engine enters and leaves lean burn.
In my car I get better mileage when flooring it in 5th rather than running partial throttle in 4th.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
MetroMPG (08-17-2012)
