Nice to see a member from NE Ohio it seems like most ohio members are from every else but the NE. To gain economy it is the safest bet to pump your tires up to max sidewall, some go higher but I stick to safer pressures, and adjust how you drive ( hypermile ). Once you learn how to effectively hyper mile you will see your mileage jump like others on here my mileage went up when i started. 26 to 32 mpg in an auto results seem to be better in a manual
"The only real mistake is the one from which we learn nothing."
- Henry Ford
