Old 08-18-2012, 02:42 PM   #1 (permalink)
seeodywhy
96 CX to HX swap hesitation.
I didn't get any responses in the other forum so I figured I would post this here.
I finished my swap about a month ago. I went through a lot of changes in order to get the swap done. The car hesitates and buck while accelerating and under light throttle. Before I installed the motor, I stripped the intake mani bare and pressure washed it so the egr ports are squeaky clean. Why would the car be hesitating? Main harness is from lx engine harness is from hx. The check engine light does not come on either. I also can't figure out why the cruise control doesn't work.
