Old 08-18-2012, 03:24 PM   #14 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I take it you know that a turbo'ed car shouldn't be EOC'ed too often?
Originally Posted by ecomodded View Post
I take it the check engine light turned off after you switched the crank sensor back on ?
Everything goes back to normal, only the ScanGauge sees a P0335 code, which I clear every now and then.
If that works then a switch will be wired / placed so a unplanned deactivation will not be likely and it is still easy to reach.
A few members have their kill switch on the gear shift knob.
You can also wire a second switch in series, only this one hidden, to use as anti-theft protection.
We're drifting off topic...
The Following User Says Thank You to Piwoslaw For This Useful Post:
ecomodded (08-24-2012)
