That could be...
I went to the junk yard and looked at an engine. It is straight forward to remove 2 rocker arms. It needs something to keep the lifters from banging on the cam lobe, I thing an o-ring stretched around the lifter body would hold it up nicely. It look like the twin cam engine cam sprocket bolt is accessable unlike the single cam engine. I suppose it could be made to run with 1 intake valve opening.
I also got a thermostat to modify.
- Tony
