Originally Posted by euromodder
If you don't want to shift into neutral, the constant speed is most likely better.
That is, if the transmission doesn't have a coasting feature built in.
There's no ECO button on the dash if that's what you are referring to; but i have noticed the transmission always tries to be in the highest gear possible, if i can manage to pulse & glide without downshifting would it be worth it?
